Visitors: 96
Total: 96
01: Pictures
17: Pictures
20: My Account
26: Event Calendar
29: Pictures
42: Event Calendar
57: Pictures
60: Pictures
64: Pictures
68: Pictures
70: Pictures
77: Event Calendar
84: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- as close as the snake bite kit....
Post Post subject: as close as the snake bite kit....
Posted: Sat Feb 24, 2007 02:50 AM
well, with the assist of Mykul, i have a loaner engine in the ol 59. I strapped in the exhaust last week and found the starter power wire today. (was thrown on top of the trans Embarassed )
my left carb had a stuck float. tapped it and she dropped (im figurin). fuel was pourin out the overflow vent like a drinkin fountain.
now it looks like the timing might be 180* out. have back fire, no start up.
should be runnin in time for the AZBAJA PIZZA NIGHT!! Very Happy
btw. if ya need to check your wiring diagram...go here: www.vintagebus.com ... scrool to "wiring diagrams" at the bottom.
Post Post subject: Re: as close as the snake bite kit....
Posted: Sat Feb 24, 2007 03:20 AM
its the dist. yanked the stock vac and installed my 009 with petronix.
the dist shaft does not want to stay seated on the timing gear in the block No! No! No! No!!!!
crank it over. remove the cap and poress the rotor down. the shaft is not aligned with the engine at all. you have to hold the shaft down and turn it slowly till it dropps into its place.
any ideas????
the dist worked in my last engine.
maybe the mechanic threw the dist during disassembly... Rolling Eyes
Posted: Sat Feb 24, 2007 03:42 AM
I bet I'm right!!!
azhunter
azhunter
Posted: Sat Feb 24, 2007 03:47 AM
Sounds to me like you have way to much end play at the dist. shaft. If I'm reading correctly, the dist. pops up off the cam gearwhile cranking? I've seen the bushings at the bottom of the distributor shaft wear out. Also might find a way to peek at the end play of the camshaft? Just my $.02
Posted: Sat Feb 24, 2007 04:28 AM
think Im gonna yank it off the block.
it had a smidgen of play before it was installed. are those bushings replacable?
maybe I should shop at the Bugzyla parts house! Wink
AZhunter...you dumpin your vw engine? got dist??? Razz
azhunter
azhunter
Posted: Sat Feb 24, 2007 04:47 AM
Yeah,,,dumping it. Sending it out monday if I get the labels.
Posted: Sat Feb 24, 2007 05:32 AM
you droppin the baja project too???
azhunter
azhunter
Posted: Sat Feb 24, 2007 04:35 PM
Oh no,,,,kids wouldn't let me. Just going to use a different power plant. I bought that 2.3 while back for $100. gonna use that. Very Happy The city moved me clear down to central and baseline so I'm trying to rush my project for gas mileage.
Posted: Sun Feb 25, 2007 01:02 AM
make sure to take pics of the transformation.... Mr. Green
Posted: Sun Feb 25, 2007 04:41 AM
I loosend the adjusting collar on the dist and removed the mounting nut. pushed that dist ALL the way in and held it there!!!!!
snugged the mounting nut down. pushed on the dist again to ensure seating. hand cranked the engine till i achieved #1 cyl at TDC. lined up the #1 cyl mark on the dist rim with the timing location and tightened the collar.
pumped the gas, turned the key, and YESSSSSS!!!!! WE HAVE IGNITION!!!!!!!!!!!!
THE ENGINE RAN (for the most part) Very Happy . it was cold and needed to warm up.
seems to be a bit rough so its gettin new plugs, wires, and a valve adjustment.....
any volunteers???? Razz
azhunter
azhunter
Posted: Sun Feb 25, 2007 05:45 AM
Soooooooooo, it was an assembly problem? Razz Glad to hear it.
Posted: Sun Feb 25, 2007 06:21 AM
I was right!
Posted: Sun Feb 25, 2007 07:42 AM
at least i had it fixed with out others hands on it. guess Im learnin Wink
Posted: Sun Feb 25, 2007 06:59 PM
Yay!!!!
azhunter
azhunter
Posted: Sun Feb 25, 2007 10:44 PM
Set defib to 360j,,,,clear!!!!!!!!!! Baja Handy is alive! Very Happy Even if it is a heart transplant/loaner.
No new posts Events and Get Togethers World Wide Nov. 5 clean it or close it 7 Dalton 3838 Nov. 5 clean it or clo...
 Sun Oct 02, 2016 02:02 PM
No new posts VW Volkswagen & Baja Bug General Discussion House Addition - Close to being done. 0 AzBaja 2526 House Addition - Close...
 Fri Jul 17, 2015 02:58 PM
No new posts VW Volkswagen & Baja Bug General Discussion Its getting close! 10 FLBaja 5281 Re: Its getting close!
 Mon Aug 03, 2009 07:31 AM
No new posts VW Volkswagen & Baja Bug General Discussion Is anyone in our community is close to me? 9 JumpinBruceB 4236 Re: Is anyone in our c...
 Mon Dec 15, 2008 03:37 AM
v-duben View latest post
No new posts VW Volkswagen & Baja Bug General Discussion close call
21 danjones333 6569 Re: close call
 Fri Dec 05, 2008 02:51 AM
danjones333 View latest post
