Visitors: 230
Total: 230
27: Pictures
28: Pictures
31: Event Calendar
32: Pictures
33: Pictures
35: Pictures
52: My Account
53: Pictures
64: Pictures
65: Pictures
74: Event Calendar
78: Home
87: Pictures
89: Pictures
90: Pictures
91: Pictures
92: Pictures
99: Pictures
101: Pictures
103: Pictures
104: Pictures
114: Pictures
116: Pictures
117: Pictures
118: Pictures
119: Pictures
121: Pictures
137: Pictures
138: Pictures
139: Pictures
140: Pictures
150: Pictures
155: Pictures
158: Baja Forums
160: Event Calendar
161: Event Calendar
164: Baja Forums
166: Baja Forums
167: Pictures
168: Event Calendar
170: Baja Forums
172: Baja Forums
177: Baja Forums
179: Event Calendar
180: Pictures
181: Baja Forums
187: Baja Forums
189: Baja Forums
190: Pictures
192: Baja Forums
193: Baja Forums
194: Event Calendar
195: Baja Forums
196: Event Calendar
197: Baja Forums
198: Baja Forums
202: Baja Forums
203: Baja Forums
204: Pictures
205: Pictures
206: Pictures
207: AMAZON.com
208: Pictures
209: Baja Forums
210: Baja Forums
212: AMAZON.com
213: Pictures
214: Baja Forums
217: Baja Forums
218: AMAZON.com
219: Baja Forums
220: AMAZON.com
221: Baja Forums
224: Pictures
225: Baja Forums
226: Baja Forums
227: AMAZON.com
229: AMAZON.com
230: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Vaccum unit
Vaccum unit
ajeden
ajeden
Post Post subject: Vaccum unit
Posted: Tue Feb 13, 2007 05:26 AM
Hi
Can anybody help me. I have just been checking my timing, which I had to adjust as the acceleration was garbage.
My VW is a bit odd. It had F.I, but now a carb, with a breakerless point distributor, which were installed before I got it. I have had both items replaced.
What exactly is the vaccum unit for, because with the timing light attached and the vaccum hose disconected and I rev the engine the timing mark moves, with the hose connected the timing mark moves?
Is the unit faulty? I always thought that the vaccum unit stopped the mark from moving.
Anyway, and help is appreciated.
Andrew from Mexico. Oh yes, my VW (vocho) is a '96
VIN70
VIN70
Post Post subject: Re: Vaccum unit
Posted: Wed Feb 14, 2007 03:17 AM
when you disconnect the vacuum line you are setting the timing for the centrifical advance inside your dist. then you reconnect the vacuum and time it again for the setting you want.
what is it timed at without vacuum? With vacuum?
Posted: Wed Feb 14, 2007 03:37 PM
W/vacuum disconnected-plugged, you are setting base idle. The timing moves due to mechanical advance built into the dist.
W/vacuum connected, you are setting total timing once the advance is "all in" for instance in a v8, you have 8 deg BTDC at idle; then 34 deg BTDC all in by 2500 rpm.
Hope that helps with your understanding. Cool
ajeden
ajeden
Posted: Wed Feb 14, 2007 08:37 PM
Hi
Thanks for the replies.
So, with the vaccum pipe removed and pluged. once the timing is set using the light, if you rev the engine the timing marks stay still?
And with the pipe connected, and rev the engine the timing marks move, because the advance mec kicks in?
It's that my timing marks move, whilst reving the engine, with the pipe disconected and connected.
Is there a way to test the vaccum/advance unit.
Thanks
Posted: Wed Feb 14, 2007 11:19 PM
Yes it will move w/vacuum plugged, but not as much. That is the mechanical advance built into the dist..
When running, you can plug a vacuum pump into the nipple on vacuum advance and build vacuum, that will test the advance. Cool
VIN70
VIN70
Posted: Wed Feb 14, 2007 11:26 PM
with vacuum disconnected the mark will move until you are at full advance then it should stop even when bringing the rpms up.
on my car right now its timed at 28* without vacuum..it wont go past 28 with the vaccum line off. then i put the line on and time it again, adjust the vacuum and its at about 40*
ajeden
ajeden
Posted: Thu Feb 15, 2007 05:45 AM
Hi Guys
Thanks a million. I think then my advance is not 100%
Will investigate further
Thanks again
Andrew
Replacement Possible or Not
3 jemizasi 3751 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
