Visitors: 392
Total: 392
12: Home
25: Links
58: Event Calendar
111: Event Calendar
132: Event Calendar
140: Event Calendar
141: Home
143: Pictures
148: Home
150: Baja Forums
151: Home
154: Baja Forums
158: Baja Forums
162: Baja Forums
164: Baja Forums
168: Baja Forums
170: Baja Forums
171: My Account
172: Baja Forums
173: Baja Forums
177: Baja Forums
182: Baja Forums
184: Baja Forums
185: Baja Forums
187: Baja Forums
190: AMAZON.com
194: Home
195: Baja Forums
196: Baja Forums
197: Baja Forums
198: Baja Forums
200: Event Calendar
202: AMAZON.com
203: Baja Forums
204: Baja Forums
205: Baja Forums
206: Baja Forums
207: AMAZON.com
208: AMAZON.com
209: Baja Forums
210: AMAZON.com
211: Baja Forums
212: AMAZON.com
213: Baja Forums
214: Baja Forums
215: Baja Forums
216: Baja Forums
217: Baja Forums
218: Baja Forums
219: Event Calendar
220: Event Calendar
221: Event Calendar
222: Event Calendar
225: AMAZON.com
226: AMAZON.com
227: Baja Forums
228: Baja Forums
229: AMAZON.com
230: Baja Forums
231: Baja Forums
232: Baja Forums
233: Baja Forums
234: Baja Forums
235: Baja Forums
236: AMAZON.com
237: Baja Forums
238: Baja Forums
239: Baja Forums
240: Baja Forums
241: Baja Forums
242: Baja Forums
243: Baja Forums
244: AMAZON.com
245: Baja Forums
246: Baja Forums
247: Baja Forums
248: My Account
249: Baja Forums
250: Baja Forums
251: Baja Forums
252: AMAZON.com
253: AMAZON.com
254: Baja Forums
255: Baja Forums
256: AMAZON.com
257: Event Calendar
258: Baja Forums
259: AMAZON.com
260: AMAZON.com
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
265: AMAZON.com
266: AMAZON.com
267: AMAZON.com
268: AMAZON.com
269: AMAZON.com
270: AMAZON.com
271: Baja Forums
272: AMAZON.com
273: Baja Forums
274: Baja Forums
275: AMAZON.com
276: AMAZON.com
277: Baja Forums
278: Baja Forums
279: Baja Forums
280: Home
281: AMAZON.com
282: Home
283: Baja Forums
284: Baja Forums
285: Baja Forums
286: Baja Forums
287: AMAZON.com
288: Event Calendar
289: AMAZON.com
290: Home
291: AMAZON.com
292: AMAZON.com
293: AMAZON.com
294: Baja Forums
295: Baja Forums
296: Baja Forums
297: Baja Forums
298: Baja Forums
299: Baja Forums
300: AMAZON.com
301: AMAZON.com
302: AMAZON.com
303: Baja Forums
304: Baja Forums
305: AMAZON.com
306: Baja Forums
307: AMAZON.com
308: AMAZON.com
309: Baja Forums
310: Baja Forums
311: Baja Forums
312: Baja Forums
313: Baja Forums
314: Baja Forums
315: AMAZON.com
316: Baja Forums
317: AMAZON.com
318: Home
319: AMAZON.com
320: Home
321: Baja Forums
322: Baja Forums
323: Baja Forums
324: Baja Forums
325: Baja Forums
326: Baja Forums
327: Baja Forums
328: Baja Forums
329: Baja Forums
330: Baja Forums
331: Baja Forums
332: Baja Forums
333: AMAZON.com
334: Baja Forums
335: Baja Forums
336: Baja Forums
337: Baja Forums
338: Baja Forums
339: Baja Forums
340: Baja Forums
341: My Account
342: AMAZON.com
343: AMAZON.com
344: AMAZON.com
345: AMAZON.com
346: AMAZON.com
347: Home
348: Home
349: Baja Forums
350: Baja Forums
351: AMAZON.com
352: Baja Forums
353: AMAZON.com
354: Baja Forums
355: Baja Forums
356: My Account
357: Baja Forums
358: Baja Forums
359: Baja Forums
360: Baja Forums
361: Baja Forums
362: Baja Forums
363: Baja Forums
364: My Account
365: AMAZON.com
366: AMAZON.com
367: AMAZON.com
368: Baja Forums
369: AMAZON.com
370: Baja Forums
371: Baja Forums
372: AMAZON.com
373: AMAZON.com
374: My Account
375: AMAZON.com
376: AMAZON.com
377: AMAZON.com
378: AMAZON.com
379: Baja Forums
380: Baja Forums
381: AMAZON.com
382: Baja Forums
383: Baja Forums
384: Baja Forums
385: Baja Forums
386: Baja Forums
387: Baja Forums
388: Baja Forums
389: AMAZON.com
390: Baja Forums
391: Event Calendar
392: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Body lift???
Body lift???
Post Post subject: Body lift???
Posted: Mon Feb 12, 2007 02:52 AM
So I'm thinking about getting the 3" lift kit. Especially since I'll be changing the floor pans and that will be the perfect time. So far I've installed adjusters on the front beam and adjustable spring plates to give me a little more height. I was thinking about running 6"-7"w front and 8"-10"w tires on the rear. My goal is to have a fun all-around Baja. Nothing serious. Will take it on the beaches from time to time.
So should I spend the extra $200-$300 for a lift kit?
Post Post subject: Re: Body lift???
Posted: Mon Feb 12, 2007 09:47 AM
I am planning on a lift. I am a tall guy, with my vert the center of gravity will be no issue. I am going to build a 2" lift, just enough to level the convert reinforcement channel with the pan.
Posted: Mon Feb 12, 2007 02:48 PM
mine has a 3" body lift. the seats were never lifted which gives a LOT of head room.
Posted: Mon Feb 12, 2007 08:38 PM
Hey bajafun,
do you have pictures posted for a look see?
Posted: Tue Feb 13, 2007 05:44 PM
yes'um.
they are in the gallery.
I will save you a trip....
Billy
Billy
Posted: Tue Feb 13, 2007 06:33 PM
I woodnt recommend it. I got one and all, and it just seems to be more of a hassle that it was worth. Now I have to customly mount my roll cage, steering column had to be adjusted of course, and I'm questioning the way the engine and erar bumper will look. Not only that, the lift kit kind got squished as I tightened the body so it has a slight bublley curve to it in some spots. THe lack of instructions and proper bolts didnt help.
Posted: Wed Feb 14, 2007 12:43 AM
yes, the steering column has to be blocked in or raised for the lift (I will give a pic shortly of mine.) you have to notch the front firewall for the steering column position.
if ya look at my pics above, you will see that there is more enginie room overhead. my cage mounts to the rear shock mounts.
Posted: Wed Feb 14, 2007 01:14 AM
steering column blocking:
front spacer:
rear shock / body mounts no longer used
rear spacer
with engine and rear cage/ bumper
Posted: Wed Feb 14, 2007 02:04 AM
Bajafun, THANKS! Great pic's. Gives me some idea what I'm in for. I knew the steering had to be adjusted a bit but was under the impression the front wall needed to hollowed out more. With the block, it looks as if thats not needed or as much. You left your seats at the same height? How tall are you? I'm afraid I may not be able to see well. I'm not a short person (5'-10") so I was afraid seat mount mods would be in my future if I lift the body.
Billy, any chance you have any pic's of yours? Especially where you say the lift kit smushed.
If I can ask Question , where did you both get your kits?
Thanks for all the replies. KEEP SENDING them please. This is very good info.
Jessie
Posted: Wed Feb 14, 2007 02:10 AM
your welcome !
it was lifted when i bought it. not sure if my uncle did the lift when he owned it...
at 6', i look like a kid sitting down in my bug with the lower seats.
Billy
Billy
Posted: Wed Feb 14, 2007 03:31 AM
That's where some of it curved out. You can't tell too much but, that's it. I wil give a better picture tomorrow and hold a ruler to it so you can see the gap. Maybe I just overtightened it. I think part of the problem was that my kit was not a sold kit. It was a piece of metal bent into shape kinda like this---> ] looking down it and then small tabs connecting the gap here and there. It is thin too. I'll post a picture of that tomorrow too. Its cold outside, haha.
That is my steering column where it connects to the steering box. After I cut the firewall I used part of a metal plate for my emissions filter or whatever it was to cover that side. Then my old man even put on that brown stuff to seal the gap. On the steering box, you see my way of connecting column to box to compensate the gap without adjusting the box too much.
Interior where the column goes in through the firewall. Random piece of metal used to fill that side of the hole and more brown stuff. Works fine now.
I got my lift kit at www.mooreparts.com Thye have a lot of good offroad parts, but, I would recommend looking elsewhere for a better kit, especially at the price! I have ordered other things from them though and have been satisfied.
Posted: Wed Feb 14, 2007 03:45 AM
GREAT! Thanks for the pic's you did grab. Yup, it's cold in No. VA too. We've been dealing with freezing rain,sleet and ice all day. Finally schools and most businesses closed this afternoon. Hopefully work will close tomorrow too so I can work on the Baja.
I guess I'll drop the body close to 3" off (most kits seem to be this height) and see where stuff rests like the steering. No seats so that won't help yet.
I to have got stuff from Mooreparts but mostly from CIP1 (Ca. Import Parts) and have been pretty happy so far. Although none of the stuff has had any road tests by me because this thing is BARE BONES but the stuff looks sturdy. In fact the lift kit from CIP1 looks good, online any way.
I look forward to the next batch of pic's and thanks again!
Billy
Billy
Posted: Wed Feb 14, 2007 03:48 AM
Ya mine is far from road, well, dirt ready as well. I hear yu!
Posted: Wed Feb 14, 2007 05:36 AM
the "brown stuff" looks like liquid nail or brown caulk. ewwww! Razz
some work is involved with a body lift. when doin the lift, repair the floor pan if needed. its easier then !
Billy
Billy
Posted: Wed Feb 14, 2007 06:10 AM
ya I pt in all new pans when I did my body lift. I woodnt have done the lift had it not needed the new pans. There is also a lot of other nooke and crannies that now need to be filled in. Ill use my brown stuff Wink He otld me what it was but I forget.
They were a lot worse than what you can see here.
25 Kreed 26144 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
Front End question
12 ButchW 7211 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts VW Volkswagen & Baja Bug General Discussion BODY REMOVAL '66 BAJA (HELP!) 5 ClassZero 4368 BODY REMOVAL '66 BAJA ...
 Sat Sep 07, 2013 05:08 PM
ClassZero View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Body Lifts 2 Darn_Near 2601 Re: Body Lifts
 Sun May 12, 2013 08:24 AM
1974 baja build
4 mkingaz 3886 Stretched pan and body
 Mon May 14, 2012 08:49 PM
mkingaz View latest post
